It's possible my Master Clutch Cylinder has a problem.
Symptoms: The clutch pedal loses pressure immediately after I floor the car and shift at high rpm, such as accelerating onto a highway. It occurs only when the rpm exceed 5,000. To rebuild the pressure, I need to pump the clutch three to six times and then it is perfect again. The pressure will remain that way for weeks with no change. But as I just mentioned, the first time I floor it and shift at high rpm, the clutch loses pressure.
At first I thought I had air in the system, but then I realized any air would affect pressure all the time. As mentioned, the pedal pressure feels great when driving normally. (I'm pretty sure that makes sense.) But here's another part of this conundrum. The system has no leaks and the fluid level in the reservoir never changes. In order for the closed system to lose pressure, wouldn't fluid have to escape for air to enter? If air enters, how does it get in? And of the course big question is why does this happen only (and abruptly) at high rpm? A clutch system is really simple, yet I'm not certain how to diagnose these symptoms.
Next, I checked online and can order a new master clutch cylinder for my car for about $86. (That's not the end of world.) To the best of my knowledge, Honda states labor to replace it is 1.5 to 2 hours. That's about $150 to $200 for labor. If I choose to do the work myself to save that $200, are there any tricks I should know in advance to get it right the first time? Or, is this one of those jobs that is worth paying to have it done?
Any opinions on my diagnosis or tricks on how to do the work would be much appreciated. Thanks in advance.
