1 - 20 of 27 Posts
Hi GUys
I just finish installing my Megan Racing 6pc Arms Kit
could anyone tell me what is the alignment spec should ?
am trying to return my car to the factory align spec, but i forget to take the reading first before i install the packege.
Another qes .. RS-R company release A Luxury Best coilover for accord hybrid CR6 .. would that fit my 2013 accord sedan 2.4 ?
http://minkara.carview.co.jp/en/userid/255681/blog/31448197/?cm=true
Thanks all
Didn't know the Megan kit fit our 9th gens too. Where did you order this from?
its the same 8th gen accord
i will help you with the parts no :
(MRS-HA-0180 / Old# 6756 + MRS-HA-0171 / Old# 6724 + MRS-HA-0114 / Old# 6757)
yes, the rear is the same on the 9th as the 8th gen.
I used the SPC 3 arm camber kit from throwdownperformance but megan is definitely quality.
corrrect .. i really like the megan kit its high quality than others i tried before
2013 Honda Accord Touring
I'm changing my air suspension from bags over struts with UAS bags, custom brackets and my D2 coilovers. To AirRex air struts once they become available for the 2013 Sedan. Stancedsport from the forum is currently doing some test fitting for them. But once I make the upgrade, I might be looking into some of the Megan camber arms as apposed to SPC.
Please school me on what benefits this 3 arm piece provide?
And Racer, you should upgrade the sway bar, it's soo tiny
Discussion Starter · #7 ·
after you lowred the car you need to adject the camber and toe again to avoid tire wear and highway saftey driving ..
am waiting eibach to release the sway bar for 2013 accord .. but i can take the risk and order 08-12 sway bar i think it will fit .. but i dont know
Thanks! Learned something new today. So the 3 arm is recommended/required when you lower the car? Or at a certain amount of inches dropped?
Why not use the TL SH-AWD 20mm sway bar instead of 8th gen sway bar?
The Progress rear sway bar for the 8th gen Accords fit 9th gens, I have it on mine.
Discussion Starter · #10 ·
whenever you lowred the car you need that kit for your saftey
i just order RS-R coilovers for my car today and it will take 2-3 weeks to be delivered ..
20mm is ok but if want to go i will use 22mm which is availble i think while am searching right now
where do you order from ? and what is the size ?
how is the progess sawy bar ?
Where and how much did you purchase these coil overs for?
hows the quality?
13 Accord Coupe V6 Ex-L
It'll be helpful if you post a direct link to the coilovers not just the site.
thanks, google translate did not translate well on my browser.
A bit steep for coil overs.
$1900+ plus shipping, that's a little steep. Are these the best of the best?? Not to be ignorant but I'm asking because I've never heard of them.
1 - 20 of 27 Posts
