Awesome! Cold air, or maybe sri with heat shield box?
The plan is for a SRI with a full airboxAwesome! Cold air, or maybe sri with heat shield box?
The plan is to use sheet metal for our airbox and we're planning on keeping the rubber snorkel similar to our CTR box design. Having the full airbox does help block out some of the heat from the engine bay, but the primary function is to aid the airflow through the intake system.Love your guy's airbox design. Does the airbox help block all the hot air? What kind of material is the air box made out of?
I’m in for this!!
I would love to get my hands on this sooner than later if it’s like the CTR design, it’s so clean it looks factory!!
We're still a little too early in the process to have a set ETA right now, but the plan for the filter is to use an oiled filter media.Any ETA on the 2.0T system? Also, what type of filter media are you going to be using?
Oiled filters are a no-go from my perspective, and I advise everyone against them. A dry media doesn't risk messing up intake tract components and can be cleaned without any special "tools" beyond soap and water.We're still a little too early in the process to have a set ETA right now, but the plan for the filter is to use an oiled filter media.
-Nick
+1. The oiling is just a crutch for the poor filtration of a "high performance" air filter, i.e. low restriction, i.e. less filtering. If you lose the oil, you're letting in molecules 100-1000x larger than the stock air filter. No thanks.Oiled filters are a no-go from my perspective, and I advise everyone against them. A dry media doesn't risk messing up intake tract components and can be cleaned without any special "tools" beyond soap and water.
This was my favorite design where it increased surface area a ton and used dry media, in the stock airbox:
https://www.carid.com/images/afe/items/31-80201.jpg
Yes updates pleaseAny more good news on the 2.0t accord intake?
We ll lucky for you it shouldn't be too much longerWaiting for a 1.5T intake!
I'm glad you asked! We actually have a post up on our blog all about our Faro Design Scanarm! Let me know if you have any other question on it and I can surely shed some more light on the equipment we use!im interested what type of 3d scanner are youre using and how do you process that point cloud data?
