I have a 4cyl. 2006 accord coupe MT and I just wanted to make sure I'm understanding this swap correctly before I decide which to go with...
So the TL 17mm rear sway bar will be fine without a front upgrade but its suggested that with a TL-S 20mm rear sway bar you upgrade the front in order to prevent potentially dangerous oversteer.
Now from what I understand, there are different options for front upgrades, two of which are the Acura TL front sway bar and/or the Honda Accord coupe V6 front tower brace?
Is this accurate so far?
If so, I understand that the front sway bar swap is a "P.I.T.A" to install, how hard is it to install the V6 tower bar? and how much does the V6 bar actually help the oversteer situation?
Also, with the Eibach Springs my car is dropped pretty low and my shocks are stock. How will this affect the handling once the bar(s) are in?
Lastly, has anyone personally tried both the 17mm and 20mm bars? If so how much of a difference between the two of them? Is the difference worth the hassle and money of tying up the front too?
Your answers/opinions/comments to any of these questions will be greatly appreciated as I am very torn between the options here as I'm sure a lot of us are or were lol...
