Does anyone else get annoyed by the mirrors on their car? The "blind spot" bend on the drivers mirror is useless and the passenger side one isn't much better. Further when the mirrors are adjusted out to eliminate some of the blind spot (the right way to adjust them) the outside 3/4" just reflects the inside of the mirror housing.
I've never had a car with mirrors designed this bad.
I agree with you about the driver's side mirror bend being useless, but after a while you don't even notice the line in the left side.
I have both side view mirrors adjusted, the right way, and I can see just fine out the right side mirror. Maybe you have it adjusted too far to the right. Move to the right to place your head inline with the rear view mirror. Adjust the right mirror until you can see just a little of your right quarter panel. When you move your head back to the normal driving position you will not see the right inside of the mirror housing. For the left side, put your face against the window and adjust the left mirror the same way as the right.
The lane watch camera is now my primary means of seeing who is on my right side. However, I do use the right mirror as a backup.
To improve aerodynamics, car manufacturers are looking ad removing both mirrors and using camera systems and sensors.
