MPG tips and test results
Hey all
I know folks come here sometimes and talk about their MPG. I've been experimenting a bit and have some quick results to share. With a little luck, I'll find the time to update the thread with more.
First of all, all results come from my 2005 LX I4 5AT Sedan. As I write this, my car has 43,219 miles on it. I recently replaced my terrible OEM tires with a set of General Altimax HP's that I purchased from Tirerack.com. All in, they cost me $311.80 including shipping (directly to the local Car-X, who installed them at an additional cost).
I downloaded a free app to my iPhone 4 called Road Trip LE (light edition) to track my mileage and cost of operation.
When I started using Road Trip I drove normally, which for me means with a bit of a lead foot. The I4 is surprisingly quick for a 4 cylinder with an auto, but the impact on MPG is pretty deep, as I found out. I fill my car until the pump stops, then wait 10 seconds and fill again until it stops again, then cap it and leave.
First result:
Oct. 6, 2010
273 mile trip
12.71 Gallons @ $2.799 per
$35.58
Cost per mile: $0.130/mile
21.48 MPG
Second result:
October 19, 2010
271 mile trip
12.14 Gallons @ $2.949 per
$35.81
Cost per mile: $0.132/mile
22.32 MPG
These numbers fell in line for the style of driving and type of driving I do. A split between highway and suburban driving of about 50/50.
At this point, I decided to play with driving style and tire inflation.
I started by filling my tires to 35 psi all around. I also committed to accelerating slowly, never exceeding 2500 rpm. I also committed to limiting my speed to no more than 5 mph over the posted limit on surface roads and no more than 65 mph on the highways (speed limits on highways are 55 mph around here but, as I found out, going 55 in the Chicagoland are really ticks people off and gets you tailgated and flipped off all day long). I also did my best to get out of people's way (I hate left lane campers who refuse to go faster than other traffic arguably more than anyone else) so as to avoid inconveniencing people. I also made sure to leave for wherever I was going with plenty of time so as to avoid road rage stemming from any chance that I would be late. If I was stuck at a railroad crossing or at a long light, I shifted to neutral and shut the car off to avoid wasting gas. I also made every attempt to time traffic lights (if I saw a red light ahead, I'd coast down in drive whenever possible to avoid coming to a stop - again, only if it meant I wouldn't be aggravating any other drivers). I also went over my route to and from wherever I was going on a given day and opted to take highways/tollways when possible and only if it made sense.
Here are the results of my experiment:
First Result:
November 3, 2010
343 mile trip
13.11 Gallons @ $2.999 per
$39.31
Cost per mile: $0.115/mile
26.17 MPG
Note: I couldn't resist passing some mopes who decided that speed limits meant they could go 10-15 miles an hour below the limit. I HATE that. If the sign says 45, don't go 30. If you do, you are a jackass. So I did stomp on the gas a few times. It felt good. I felt better. Then I felt guilty for screwing up my experiment and decided I would just pass gently for the next tank to see if it made a difference.
Second Result:
November 17, 2010
392 mile trip
13.28 Gallons @ $2.999 per
$39.81
Cost per mile: $0.102/mile
29.53 MPG
That's it for now.
From 21.48 MPG to 29.53 MPG through behavior modification, slightly overfilling my tires, and planning. That's an 8.05 mile per gallon increase in fuel efficiency. It's also an efficiency increase of 37.47%!! It also represents a decrease in cost per mile of 21.5%!!
Fueleconomy.gov lists the 05 Accord 5AT I4 as 21 city, 31 highway, 24 combined. It also lists MPG estimates from drivers at 26.5 MPG.
It's working. I find myself more relaxed and enjoying my commute more. I'm saving cash and using less gas.
If you have questions, let me know. I'll try to keep updating my stats as I go. If you are experiencing MPG that you think is too low, try filling the tires to 35 psi all around, accelerating slower (keeping it below 2500 rpms), planning your route a little more carefully for efficiency, and leaving for where ever you are going with a little more time than you think you may need.
Good luck! :wave:
Hey all
First result:
Oct. 6, 2010
273 mile trip
$35.58
21.48 MPG
Second result:
October 19, 2010
271 mile trip
$35.81
22.32 MPG
First Result:
November 3, 2010
343 mile trip
$39.31
26.17 MPG
Second Result:
November 17, 2010
392 mile trip
$39.81
29.53 MPG
That's it for now.
Good luck! :wave:
