I've been trying to fix an oil leak for almost two years coming from the Vtec Solenoid and no matter what it continues to leak, but lately it started to leak even more than usual, so checked the solenoid and found oil on the top of the Vtec solenoid assy. See pictures below.
Already got that 18x1.5 mm O-ring to replace, but just wonder if I need a special socket to remove the oil pressure switch??
What do you guys think? Is the leak coming from that O-ring? Does not seem to come from the valve cover gasket which I replaced a year ago (OEM and torqued properly).
Thanks in advance.
Video:
Thanks in advance.
Video:
