It is looking realy god so far, good job :thumbsup:
you mean the red and black wires right? where does that connect to? the OEM car harness? how should i do it, just shove the wires in the harness and like electrical tape it?hey for the bulbs rip out those 2 pin with the 9006 plug and throw them away. You won't be needing them.
Dont go with there diagram is stupid. They are dumb. This is what you do. car to ballast, ballast to bulbs. Rip out those 2 stupid pins. They are used for H1 headlights. The ballast has 9006 connectors so it direct fit from your car harness. If you want run a relay from the battery to the ballast.you mean the red and black wires right? where does that connect to? the OEM car harness? how should i do it, just shove the wires in the harness and like electrical tape it?
@aznaccord08: this is actually my first retro so i dont really know what im doing that much haha. i mean the MH1 i think is pretty easy since its a PnP. if i were to do the other ones like TSX, i would probably break everything haha.
