1 - 20 of 25 Posts
2007 4DR EX-L V6 5AT
All 5 of my DIY's have been uploaded to Google Docs. It should not require you to sign-in, but you never know. Let me know if there are any issues. Here are the links to all 5 and also the folder they are located in:
Folder:
https://docs.google.com/leaf?id=0B-A8fddylRMAMzRlMDY2YjUtMTE1OC00YTQ1LWI1YWQtZjhkMTQ1MWMxYWZk&hl=en
TSX Retro:
https://docs.google.com/present/edit?id=0AaNeIkCy6iSHZGc3dDZ4czdfNzFkMms0dHJmNA&hl=en
ES3000 Fog Light Retro:
https://docs.google.com/present/edit?id=0AaNeIkCy6iSHZGc3dDZ4czdfMTNkZ3pxYndmNw&hl=en
Blackhousing Headlights:
https://docs.google.com/present/edit?id=0AaNeIkCy6iSHZGc3dDZ4czdfMGRrdjY4NGQ3&hl=en
Front Bumper and Headlight Removal
https://docs.google.com/present/edit?id=0AeA8fddylRMAZGQ2cXQ3d18zNzl6NG1ncDQ0&hl=en
Replacing Cracked Lens with Lexan:
https://docs.google.com/present/edit?id=0AeA8fddylRMAZGQ2cXQ3d180ZjJjcG14YzI&hl=en
Mud/Splash Guard Installation (7.5 Gen Sedan)
https://docs.google.com/present/edit?id=0AeA8fddylRMAZGQ2cXQ3d18xOGc2NTJkamR0&hl=en
Prim and Proper
The text in the first slide of your blackout DIY is cut off. Otherwise looking good. I didn't look at any of the other ones yet.
The taste of Vtec!
says i dont have access to the documents o_O
Prim and Proper
its not cutoff for me, what exactly is cut off? is it the intro slide?
No sorry it's in the second slide. Everything after: "Carefully lift up tabs around seal and use flat" is cut off for me.
2008 Honda Accord V6 EX-L
Aww it says I don't have access :-(
"We're sorry, but [email protected] does not have access to this document
You are signed in as [email protected], but that email account hasn't been granted permission to access this document.
Please sign in as a different user. Otherwise you can request access to this document.
Find out more about this topic at the Google Docs Help Center."
Too old to tolerate
Nice work Greg!
Not to be the sour note but why you didn't went like the IHL: HID and ballast w/o the PIA retrofit?
Just my
'06 Coupe EX V6/6MT
It appears to be working for me now from another workstation - so, I know I'm not logged in as me, but I can see the doc. You musta fixed it, it def wasn't working for me earlier.
I think this deserves a STICKY
1 - 20 of 25 Posts
