1 - 2 of 2 Posts
I recently replaced the rear main seal on my 2000 LX-V6 myself. Everything work fine but now some times the key will not come out of the ignition switch without jiggling the shifter handle. Few quick jiggle in park position and the key gets released. Everything works just fine.
When I pulled the tranny out, I had to remove the shifter cable connection which only goes one way and there is no adjustment there.
Is there any adjustment in the gear selector handles itself?
What else could be causing this?
Thanks
Waid
The shift cable has an adjustment on the side of the shift lever assembly. Remove the center console to access it.
1 - 2 of 2 Posts
