1 - 12 of 12 Posts
Car so nice, bought twice
(I didn't put this in the Fluid Dynamics section, because I feel it's 8G specific)
Looks like my engine might be getting run pretty hard. The broadstrokes being my oil (4 qts Amsoil with .5 qt Redline) with 2500 miles on it and 6 months time shows wear metals on par with oil that's been run for 6800 miles. I'd have to check my records, but I think I've done 3 or 4 oil changes now so I'm definitely on a short interval.
Text Font Parallel
Moved. Otherwise no one would ever post in this section if they went by generation only.
Fine by me. :thmsup:
How is this 8th gen specific? Just because you own one? It's the same ubiquitous 2.4l that's been around since 2003.
Had to do a bit of research on this, but it appears the 7G engine is functionally as different as the 8G as the 9G is to the 8G. 7G being K24A, 8G being K24Z, and 9G being K24W. Cosmetically Accord I4's all seem similar.
Corvalis TTX
Well this is a family car and maybe the engine just isn't designed to be pushed as hard as you claim you push it? Perhaps a more performance oriented car is in your future?
Discussion Starter · #7 ·
I've been driving a bit easier recently. Mainly because I've mostly had to do city driving where pushing hard is dangerous and doesn't really save any time with all the traffic lights. I'm expecting the next oil analysis in June will show drastically reduced wear. The Amsoil seems to do pretty well with my short commutes where the engine barely has time to reach operating temperature (high TBN).
Corvalis TTX
Hopefully the next analysis will be better. Keep us posted.
What does this mean? (high TBN)
Discussion Starter · #11 ·
[/B]
I'm basically just repeating what I've learned in about 10 minutes worth of googling, but TBN seems to stand for something related to how basic (as in acidic or basic) the oil is. TBN > 1 means the oil has the ability to neutralize the acids that are generated via cold engine running.
High TBN means the oil is still serviceable as long as the wear metals are low. High wear metals + High TBN (which I'm on the border of "high wear") means you need an oil change, even though in theory you could filter out all the wear metal and put the oil back in.
Discussion Starter · #12 ·
Updated at 28k miles.
Wear metals still high, much longer mileage on this oil change. Seems that driving hard indeed adds more wear, but tuning and 7500 rpm redline doesn't seem to have dramatically increased wear. On the first analysis I wasn't tuned.
Filter was Fram Ultra.
1 - 12 of 12 Posts
