The compass on the HUD disappeared. I used the home button but it doesnt come back.up.
had the same problem. updated the navigation and it worked.Is your navigation booted up? I have noticed that when my infotainment reboots the compass does go away for a while until navigation comes back on.
The HUD only comes on both the Touring Trims, 1.5 or 2.0L engines.Hello,
Does the HUD only come with the Touring or can you buy it as an upgrade to other packages?
Does the HUD give you HUD from Android Auto for directions or is does it only work with the Honda navigation system?
Interesting. The HUD does NOT display turn by turn navigation from Apple CarPlay (or at least I haven't been able to get it to do so). I think I may ditch my iPhone for Android just because it seems as if Android Auto is a step ahead of CarPlay... at least with integration into the '18 Accord.The HUD only comes on both the Touring Trims, 1.5 or 2.0L engines.
The HUD also gives you upcoming directions using Android Auto, which is really nice and I did not expect it to. The HUD will of course display stock navigation.
It's pretty nice in use, and you can set the tilt projection level, as well as the brightness. It is also in full color.
That's interesting, the only reason why I would think that it has better interfacing with Android Auto is due to the headunit running Android itself, but with iOS, not sure if Apple has programmed that capability. I much prefer AndroidInteresting. The HUD does NOT display turn by turn navigation from Apple CarPlay (or at least I haven't been able to get it to do so). I think I may ditch my iPhone for Android just because it seems as if Android Auto is a step ahead of CarPlay... at least with integration into the '18 Accord.
It's visible, but polarized glasses will definitely wash it out to the point that it's almost unnoticeable. There's not much Honda can do about this, though.When I drove the Camry my polarized sunglasses caused the HUD to disappear (possibly the brightness could have been set too low) but it was visible in the Accord.
