Does anyone have a DIY outline on the best way to remove and replace the rear motor mount on a 2010 Honda Accord 2.4L. Step-by-step written instructions or photos would be a big help.
You'll want to keep the mount loose and you should be able to wiggle the engine around with it sitting on the jack w/ a piece of wood. I've found using silicone lube helps line up the mount and the bracket just a tad easier and then I ended up sticking a small screwdriver on the opposite side of the hole where the bolt goes through to get the bolt started and I was able to kinda push it the rest of the way through while spinning the long bolt.Thanks for all the help. I was able to replace the rear motor mount today with few problems. It was not very difficult. I did reach an impasse, I am having difficulty getting the long bolt lined up in the bracket, the bolt that goes through the bracket and motor mount. Any tips on getting the bolt threaded and started once through the bracket and engine mount?
Did you remove the mount from the top of the engine bay or underneath? Thanks!Thanks for all the advice, instructions, and diagrams. I was able to remove and install the rear engine mount in under an hour. First I supported the engine with a jack and 2x4 under transmission/engine. I first removed the long bolt that goes through the bracket and engine mount. I then removed the engine mount and bracket that attaches to the engine. Together as a unit with the long bolt going through the bracket and engine mount, I installed the engine mount and bracket. I lined up all bolt holes and just hand tightened each bolt until all were installed. I then torqued down all bolts.
For me I noticed more vibrations in the cabin especially in drive, foot on the brake with the AC on. It helped solve that issue. I also took pics of the mount and saw cracking on it so I figured it's now or in a year or 2 and bit the bullet. Just visually inspect the mounts, I believe some of them are fluid filled so if you see cracking, or oil leaking from them then it's time for new ones. Also go OEM, you will not save money using junk chinese aftermarket mounts.Just wondering, what symptoms did you run into to end up deciding to swap the rear engine mount? I believe I may have an engine mount problem, but not sure which one it might be.
