AcuraHondaExpert, super kool and helpful dude...spoke with him for like a good hour and helped out a lot and basically even would loan me his display for a fee but gonna look locally
so close to being done and like he said, gotta be patient and do it right
k for the PMs i've gotten about doing OEM Navi w/OEM Harness, this is a way to make sure you have a good Navi Unit. i am missing the Final Step of mine being the Upper Center Display thus i can't fully install it yet
everything else:
Navi Unit
DVD Rom w/CD
XM Radio
OEM Harness
couple tools:
2 Fuse Holders if you will not buy these STOP, you could seriously damage your Navi Unit by shortening it so spend the $5-6 bucks and buy 2 fuse holders
exacto Knife
wire
i've figured this out on my own and took a risk but i spent days reading over the Navi Manual and got this Unit on eventually so hopefully, it'll save you a lotta time and effort to make sure your Navi Unit is good
5 out of 10 on skill level because most of the hard parts i tried to test/do on my own
1. The 2 Fuse Holders that will hold 1 10 Fuse & 1 7.5 Fuse. Again, if you will not go out on buy these, you assume a greater risk of possibly shortening your unit in case something goes wrong. These can be hooked up directly to your Positive Battery terminal as all your doing is testing the Unit
2. Navi Manual Page showing the main connector on the back of the Navi headunit (scroll up to see in pic very top, Blue Connector on backside of Navi Unit)
3. The 2 Wires: White/Red Stripe & Yellow/Red Stripe are the 2 power wires you want to splice into. DO NOT CUT them, just take an exacto knife and slowly peel the wire cover (you'll get better w/time but try not to cut the wires)
4. The other 2 Wires are on the DVD Rom Unit same colors, WHT/RED & YLW/RED. They are also Power wires and same thing as above, splice into them rather than cutting
5. SCS Connector on DVD-ROM wiring that you'll be sticking a piece of wire or paper clip, i used wire but paper clip may be safer
6. Spliced Wiring:
7. Then put them both together WHT/RED + WHT/RED and YLW/RED + YLW/RED. 2 WHT/RED are 10A Fuse and 2 YLW/RED are 7.5A Fuse. Connect the 2 wires to Positive Battery and this screen should pop up after loading screen.
All colors RGB, Touch surface, seem normal basically missing the the Sub Display to unlock Audio
there is 1 White Connector that is missing and i'll take a pic of it
so hopefully this will help someone who wants to make sure there OEM Navi Unit + OEM Harness + OEM DVD Rom + (optional XM Radio and Voice/Mic Steering Wheel Buttons) should all be working
