1 - 3 of 3 Posts
there's this small scratch on the rear bumper that i tried using scratchX to remove it but it's not working. any ideas how i can repair this?
one of the headlight covers has this white substance thingy in it but im not sure how to clean it. i tried spraying water in there but that didn't work. the opening at the corner is too small to put something like a cotton swab in there.
↑ ↑ ↓ ↓ ← → ← → B A
How deep is the scratch? Does it catch your finger nail?
From the pic, it doesn't look that deep but it may be deep enough that Scratch X and/or trying to get it out by hand aren't enough.
Do you have Meg's Ultimate Compound? It's got more cutting strength than Scratch X. If UC still doesn't work by hand, then you'll need a machine (dual action orbital or rotary) to get it out.
If it is deep, then it needs to be filled with touch up paint, wet sanded, and polished with a machine, or just repaint the area.
Not sure about the headlight. Is it on the outside (can you feel it with your fingers?) or inside? Almost looks like dried wax. If it's on the outside, try a clay bar or apply some rubbing alcohol with a microfiber. You could even try the Scratch X.
If it's on the inside, no way to get it out without cracking open the head light housing.
I tried removing the scratch with meguairs ultimate compound but it only partially remove some of it. the upper end of the scratch it does catch your fingernail.
for the headlight, unfortunately it's in the inside. i never open one of these before. there is a small opening at the corner, may be i can slide something in there to clean it up.
edit: i improvised and used drink straw to clean up the headlight lol. i just made one end flat, squirt some window cleaner spray on it and inside the headlight cover and drag the straw up and down.
1 - 3 of 3 Posts
