I recently purchased a 2016 Accord LX. There were 11 miles on the odo at delivery, the car was originally inspected by the dealership in April 2016, and had been in the showroom for a while.
1. Is there any reason to change the oil right away, given that it's been sitting for over a year? I see no indication on the post-purchase paperwork that would indicate that any fluids have been changed, and the Maintenance Minder system still shows oil at 100%. I trust the MM system, but it's not omniscient for all situations. I definitely want the engine to have maximum lifetime, and don't want to screw up the break in period.
2. I would like to do at least the oil changes and tire rotations myself (A 1 Maintenance Minder items). Am I correct in understanding that the MM system should only be "reset" once all items have been performed for a specific group of services? For example, if there is A(oil) and 1(rotate tires), and I just rotate tires + reset the system, then it will just assume that I've done the oil change (ie there's no chemical detection system that says the oil should be changed). This is particularly relevant because I'd like to rotate ever 5,000, not 7,500 miles, to extend life of tires.
3. Is there a way to see what index from the MM is up next? or to toggle through the MM system to tell the car "hey we're actually at a different interval now"?
For example, let's say that the order is 1) A1 at 7500, 2) B2 at 15000 , 3) A1 at 22500, 4) ... (just making up those data)
And I or someone else accidentally skips over #2, can I access that the car mistakenly has A1 cued up, and can I change it to index back to #2 B2?
4. I have snow tires (195 Nokians) from another vehicle, used just 1.5 months. The OM says that 205's should be used, but most people I know also put narrower snow tires. a) is it actually ill advised to use narrower tires? of course, I'd mount new wheels to fit the Accord appropriately. b) as long as the tread wear is even--I haven't actually checked this--, is it okay to use tires used by another vehicle? It was an AWD 3 series BMW, if that makes any difference in tread wear opinions.
I know there are lots of questions here. Thanks for any advice you could provide!
