1 - 2 of 2 Posts
Hey all, my Silver's NeoMax coilovers w/ Swift springs are on the way! This is my first major mod to my '16 Accord Coupe V6 manual.
I believe I need to upgrade to adjustqble rear arms in order to get the correct camber dialed in. I don't want to go cheap, but do I really need the complete 3 arm kit, such as the Voodoo13 below? I am planning on a 2-3" drop and a 1.5-2.0° negative camber front & back.
I'm also getting the Progress 25mm rear sway bar:
Do I need adjustable end links? Front & rear or just rear if I'm leaving the front sway bar stock (for now)?
Discussion Starter #2
Buy once, cry once: I picked up the full Voodoo13 3-arm (6 total) kit from heeltoeauto.com w/ the Progress sway bar.
Now to choose the best adjustable end links:
I'll need to measure the current sway bar angle and then after installing the new coilovers, find an adjustable end link set that will return the sway bar to its original position.
1 - 2 of 2 Posts
