This car has sat for at least 8 years, but the engine turns by hand fairly easily, so I know the engine isn’t seized. I’ve tested the ignition switch, it was burnt and bad, so I replaced it. Not overly burnt, but wasn’t making contact. Next tested the transmission range sensor, it’s good. Tested some wires going to the starter after pulling intake manifold, and I’m not getting voltage to the starter solenoid. I do however have continuity. I swapped the starter cut relay with what looked like power windows relay, as well, with no result. Next, I jumped the starter solenoid contact to the positive battery terminal, and was unable to get it to crank. I pulled the starter and had it tested at Napa, only to find it did crank on their machine, and worked good. (No idea if it can push a load though). Then, I tested continuity from the main starter power wire to positive battery terminal, good. Also tested continuity from engine head to the frame ground bolt, that was good. I’m at a loss here, is everything really good, or is my wiring diagram missing some parts?
