1 - 6 of 6 Posts
Is anyone having noise issues with 2013 Crosstour? My car is extremely loud at speeds above 40 mph--road and tire noise. I carried it back to the dealer thinking insulation was missing. I was told no problem with the car. So loud I can not use the Bluetooth.
Koko Lago
I just got my Crosstour from the shop, for a noisy front suspension. They ajust all the front suspension and found a bulletin for the replacement of the lower front ball joints... After the ajustment I feel a 95% improvement, but need to complete phase II by replacing the ball joints... Crosstour is great, better than my previous BMW...
Fear The Turtle!
Test drive a new one or a used one on their lot, that should tell you whether it's normal or not.
Do you have a roof rack? They can be very noisy.
the noise you hear is it more of a humming sound ? if it is, have them check your wheel bearings.
i had an issue with my accord with the rear wheel bearing humming. soon as i hit 40 mph and then go away at 60 mph.
hope it helps because i don't own a crosstour.
1 - 6 of 6 Posts
