1 - 6 of 6 Posts
Ceannt38
I need a obd ii scanner/programer. I want to check the compression and the factory manual has you turn off the injectors in order to do a compression test.Can anybody recommend one that won't break the bank. but will do the job. I have not priced Honda's part
thank you
BRWNFLSH now
I doubt a scanner is going to have the ability to turn off the injectors. Maybe there is a fuse you could pull.
Car so nice, bought twice
Appropriate: lolwut?!
Just unplug the fuel injector connectors (all cylinders), remove spark plug on cylinder you want to test, test it, rinse and repeat. Or as BLCKFLSH suggests, I'm sure there's a fuse somewhere for the injectors.
Bob's your UNCLE ...
Does anybody use Dashcommand app for Android? If so, how to see the numbers for ltft 1 and ltft 2? I have the trial version and it shows only ltft but not separate numbers for ltft 1 and ltft 2. Or is the ltft 1 and ltft 2 feature present only in the paid version? I'm using ELM327 with OBD Car Doctor Pro app (paid version).
1 - 6 of 6 Posts
