Hey all...been a while.
So my 06 4cyl is consuming a lot of oil.
I've measured the consumption and it appears to be consuming about 3+ quarts per 1700 miles. Basically, after a new oil change where the oil level is at the full mark on the stick, it's only 1700 miles before the oil is at the fill/needs oil mark on the stick.
No oil slicks/drips on the drive way, no oil spots on the underside of the vehicle, no plume of smoke out the back.
I have 75k on the engine. Never been any issues with the car before. This consumption started around 10k miles ago and has steadily gotten worse.
Any thoughts, solutions...
I spoke with a Honda mechanic I trust and they said (with the caveat that they need to see it in person) it is likely a problem that will require a replacement engine.
I have an extended warranty which will cover pretty much anything with the engine including replacement, so I'm not terribly worried. I'd just like to know what some of the potential causes for this could be.
