I loved my 2005 Accord EX-V6, tranny went at 165K, so I decided to get a new car as I drive over 42K a year. Great car, not the best brakes, but I did my own anyways. I miss that car...
I bought a new 2009 Accord EX-V6....what a mistake.
13 months later, I regret buying this piece of crap.
All the threads about oil consumption, they are true. If you don't experience it, you are lucky. I change mine every 5K, and the dealer did my first at 5K, they wanted to change it at 3,750. The dealer never mentioned anything about a "break-in" oil with magical powers, just to bring it in at 3,750.
At 10k, I drained about 3 qts, a loss of 1.5qts in 5K miles. (But my maintenance minder said 50% - too bad it doesn't measure volume, so could I have no oil and still have "life" ? (nice feature Honda)
So i figured about 1/2qt every 1500-2000 miles oil burned. Brought it to the dealer with a long list of problems with the car, but oil consumption being my biggest concern. I was told it was "within spec". Honda will only fix if I burn 1qt every 1k miles. I told them why change the oil, just add a qt every 1k, same as a 5K oil change. They were not amused.
Then Yesterday.....
I got off the highway, went through the toll booth, and bang - no power, engine shaking, vibrating, then a engine light, but still running. Oil was good, I just checked it the day before. (Remember a few years ago when you didn't bother checking the oil because it was always good? That's how my 2005 Accord was....drive 5K, drain 4.5qts, refill 4.5qts)
Went straight to the dealer, and today was told #3 cylinder spark plug was fouled, replaced one plug, flashed the computer per the TSB. Tech said he checked all of the plugs, but only #3 would be covered by warranty. I asked to see the plug, and guess what - oil fouled. How can that be?? According to Honda, there is no problem with oil consumption.
My 2009 has 46K miles, when the plugs were changed in my old 2005 at 105K, they looked almost brand new. I finally got the tech to admit that he has seen this on Hondas with far less miles.
Hopefully the flash fixed the problem, but I have ZERO confidence in this fix, or the car as a whole.
Maybe I'll call the guy that bought my 2005, and buy it back. Seems Honda new how to make a good car back then.
BMW68
The 68 stands for my 68 Camaro - it doesn't burn oil, but my Accord does!
Then Yesterday.....
BMW68
