I found some oil in my driveway and decided to check my oil level. It was low... VERY low. I got under the car and there was oil everywhere. The mess is mainly on the passenger side, not particularly in the front or the rear, however the oil pan all the way up to the the valve cover is soaked. The problem seems to be coming from somewhere up top, but below the valve cover. Here's what's odd: there is no oil on or around the oil filter, the exhaust and intake looks good, and the valve cover (gasket) has no oil on it. The VTEC solenoid is one of the most common issues I've found but mine once again looks clean. But like I said, everything else in that area is a complete mess and I wouldn't be surprised if oil was being slung all over everything while driving (my belt looked clean).
Without further adieu, here are some pictures (very large, I know, but hopefully somebody can recognize the issue!):
From underneath, there is an obvious leak
From underneath, looking up by the passenger wheel well
From top, THE TROUBLE SPOT
^What is the round thing in this picture, with the plug going into it? That looks like it might be an issue
From the bottom, looking up at the trouble spot from above. Notice the oil filter and VTEC solenoid are pretty much completely dry
Thanks so much for looking,
Zach
Zach
