Hey guys. When trying to remove/install the 2.0L engine oil pan, the lower torque rod mounting bracket is secured to the pan with 4 bolts. Anyone know the torque spec for these?? Thanks in advance for any help!
no problemo, i like trying to help people. how come you are removing/reinstalling oilpan? are you doing some maintenance or is there an oil leak? just curious to know more about this kind of stuff in case it is something i might try to do down the road. let us know how it goes.Found the torque spec on the forum like you suggested. Don’t know how I missed this earlier! Sorry to trouble you and thanks again for taking the time to look and reply.
lmaooo oh man that is rough. yea it might be that maybe it is not necessary to replace those bolts, maybe a more experienced person could comment on that. that sucks though, especially since they label 'oil ->" next to the drain plug hahahNo, it’s because I am an idiot. Was doing an oil change and got distracted. Instead of loosening the drain bolt, I loosened the bracket bolt (both 17 mm heads)! Oil change went fine but now I gotta spend time and money getting the bracket bolted to spec. Doh!
Totally agree. The other car I have, I did take to the dealership the first couple of years. Then I started doing my own work and found missing or over torqued bolts that they never told me about. Scratches in the paint. Chipped calipers. The list is endless.That's still why I change my own oil, garages do stuff like this and don't tell you.
Unfortunately, a ball bearing had fallen out from the starter motor and I couldn't get it (the ball bearing) back into place. Did re-install the starter, but it wouldn't work. Had to have my truck towed to Nissan dealer. They did a good job on the replacement. Haven't had any trouble with it since and that was way back in 2009.Ouch! Why did you need a replacement though? If you removed it, could you not reverse the steps and install the same motor?
Don't be too hard on yourself. Crap happens. The other day I burned some water when I went to boil it.Tell me about it. Like I said, I am an idiot. This isn’t even my first oil change either.![]()
Heard too many horror stories. I tell friends at least check your oil level when you leave an oil change placeTotally agree. The other car I have, I did take to the dealership the first couple of years. Then I started doing my own work and found missing or over torqued bolts that they never told me about. Scratches in the paint. Chipped calipers. The list is endless.
This is the way.That's still why I change my own oil, garages do stuff like this and don't tell you.
yea they messed up a lug nut on my wife's rogue and said " it was like that when it came in"This is the way.
I've gotten burned so much in the past, I'll even go as far as taking the wheels off the car to get them changed if I need new tires. Auto shops ALWAYS use an impact wrench and go WAY WAY over torque spec on lug nuts. One time they did this and it snapped a lug nut off and didn't even say anything. I got the car home and ask them about it and they said it was fine to drive on 4 out of 5 lug nuts. I was fuming. F that!
