1 - 8 of 8 Posts
2004 i4 5AT 4dr
While checking my oil, I noticed that the air intake temperature sensor did not look like it was inserted all the way into the intake tube. So I disconnected it and reconnected it (engine off). My check engine light came on and the OBD2 scanner showed a P0113 air intake temp sensor code. What I find weird is that I can’t erase the code. I even tried disconnecting the battery and the code is still there.
When looking at the live data, the air intake temp shows -37°C which is weird because the outdoor air temperature is around 0°C.
Will this sensor “self-adjust” or is it something I should replace?
See attached images…
Thanks
Communication Device Portable communications device Gadget Telephony Mobile device
Font Display device Gadget Rectangle Electronic device
2004 i4 5AT 4dr
Despite the CEL disappearing, the intake air temperature was still wrong and it bothered me. Turns out, the sensor nipple was broken off.
Honda dealer wanted $80 for a brand new IAT sensor (P/N 37880-PLC-004)
Decided to go to the scrap yard and collected a couple of IAT sensors for $15.
Intake air temperature readings are now correct.
1 - 8 of 8 Posts
