1 - 4 of 4 Posts
So I keep pulling these 2 codes which are supposed to be related to the o2 sensor heater. Here's the strange thing; according to my KTuner, my AFR is "stuck" at 10.1:1. It never moves until I turn the engine off. It runs fine though. This all started when I was trying to hook up an AFR gauge (which is still not hooked up) and I looked up the sensor output wire on my alldata. It told me there was 2 output wires. I tried both, and the gauge would not register anything. The best result I got was the gauge pinned to full rich. So I tried all of the wires, except the ground. Shortly after, I cleared the codes and the CEL immediately came back on. I also installed a set of PCD's with no issues. They are used and the de-foulers are mostly adjusted correctly. I replaced both upstream o2 sensors and I am still getting these 2 codes. What's worse is that I STILL dont have a working AFR gauge... Can someone please tell me wth is going on cause I am stumped. Thanks!
Turbo lag
Check the O2 sensor connector. I had an O2 sensor where the connector pins will back out for some reason. A dab of glue fixed that. The car runs open loop when O2 sensor is not working.
Thanks Hudouc, I will check them tonight. I will say that I am fairly certain that all the connections are good, but I will check anyways cause what could it hurt? Will post an update soon but in the meantime if anyone else has any thoughts, I'm open to hear them, thanks!
Turbo lag
Wait, I just realized you have a V6.
According to the service manual, check the No.14 FI SUB 15A fuse (fuse box under the hood), and also the PGM-FI subrelay A.
1 - 4 of 4 Posts
