My cousin has a 6th gen (v6) with some idle issues that she's asked me to help her out with.
Basically the car was just sitting for a year not being driven around or anything. After she got rid of her truck she had her mechanic come down to replace all the fluids and re-do the brakes. I'm not sure what else he did though.
A few days later, her car throws a CEL and the car idles funny she said. I hook up my code scanner and it's a P0505 code for idle issues. I go online to search and the CEL code thread only has "14 P0505 Idle Control System Malfunction" as a description. I also come across THIS thread which says to check the IM and IACV gaskets.
Knowing that this is likely a gasket or vacuum issue, i'd like to know which vacuum lines this could be coming from if it is a vacuum line. If this is a gasket issue, I want to ask which gaskets the IACV and IM are. Is the IACV gasket the one where the throttle body is at and the IM gasket the one where you would have to take apart the entire top part of the engine to get to as if you were cleaning out the EGR port?
I just want to know what to expect ahead of time before my cousin calls me or her mechanic up for this job.
