1 - 11 of 11 Posts
I have a 2011 Honda Accord EX 2.4L 5MT, and when I got the car if I were to pull the hand break up all the way it would decently hold the car enough where I didn’t need to put it into gear unless it’s on a steep hill. Now if the car is on any incline or decline whatsoever it begins to roll. So what I did was I tightened the 12mm bolt under the center console from the backseat like many videos have suggested. Now when I apply the break it only goes up about halfway and seems very stiff and like it is doing something very effective. Only to find out that as soon as I let off the foot break there is no difference! Now I have to leave the car in gear when I park which I typically don’t like to do, but that is my only option at this point. I’m sure I need to do something at the back wheels but I’m not sure what. Anyone else know what to do?!?
Runnin' in the 90s
The parking brake uses the rear brake pads. You can have those checked and replaced if necessary. Calipers might be sticking also.
Yea I modded my car again
If those levers on the rear calipers are sticking then it's only a matter of time before the brakes start to seize and roast the rotor/pads. Happened to me (canada struggles)
You can throw in some PB blaster in the hole the lever enters the caliper (thats what I did when I bought the car 3 years prior). Later when they did roast the pads and rotor for $150 I ordered two rebuilt calipers and it's gonna work perfectly for a very long time.
Old Bird...sometimes wise
Brake
Description
A brake is a mechanical device that inhibits motion by absorbing energy from a moving system. It is used for slowing or stopping a moving vehicle, wheel, axle, or to prevent its motion, most often accomplished by means of friction.
Break
DESCRIPTION
to smash, split, or divide into parts violently; reduce to pieces or fragments:He broke a vase.
10 EX-L V6 Coupe
New calipers are indeed what you need, OP.
Reman'd are cheap as 6/6 mentioned and it's a straightforward job to install.
I replaced my rear calipers for this exact issue. I remember that it was surprisingly cheap. I just bought some cheap calipers on amazon. Installing was also surprisingly easy.
Discussion Starter #10
update: i replaced my rear calipers and this solved the issue. i now have a like-new parking break!! i did the rotors and pads while i was at it and it works great. i wouldn’t bother with and OEM one. i just went to autozone and got referbished ones
It's always a great feeling when you fix a big issue for a little price :) .
I am crazy about my brakes. If the rotors are not in perfect condition I have to fix them, not for safety , because I am OCD with how they made the car look like crapola lol
1 - 11 of 11 Posts
