1 - 10 of 10 Posts
Im not sure what you call it but I see in the diy videos that people have some plastic tool they use to pull the trim off when getting to the radio. What is that called and where can I order one that is good.
sorry if this is a dumb question.
Vtahk didnt kick in
There is a yellow kit with 5 different plastic tools at harbor freight, 6$ and works great
Link?
I also found that tire levers work well, at least better than a flat head screwdriver and they can be found at your local bicycle shop.
Discussion Starter #6
thanks for the link
The problem I found (the hard way) with a flat head screwdriver is that it can leave indentations in the plastic trim.
that why u wrap the ends thoroughly with something like scotch tape when in a pinch (or use a butterknife that's wrapped in the same method..)
I highly recommend for the price the HF set mentioned above .. it's helped out a lot over the past couple of yrs
Discussion Starter #9
I need to order that set. I was going to pick up a ipod hookup for my car but it looks like my ipod is going bad now.
The set that Los kindly posted the link to looks very good - especially for the price. You might want to check out this other set as well. I bought one a couple of years ago for $5 (too bad it's not on sale now). I like it's variety and it's always worked well for me. But I'm sure either set will do the job. Good luck with your install.
http://www.harborfreight.com/automo...ece-auto-trim-and-molding-tool-set-67021.html
1 - 10 of 10 Posts
