1 - 20 of 21 Posts
hello ppls, well i brought ebay fog lights kit. i have the lights on the bumper, with HIDS. the only thing i cant figure out is the wiring. i tried searching but i cant find anything.
in the pics the only thing is that i dont know where the grey, and brown go?
the green one is for the switch. the grey has just on wire which is red(has to be power) but where does it go?
the brown one i have no idea. if someone can help.
thanks.....
i kind of need a better shot, but i think the red wire one goes to whatever is going to switch the relay, which i would use the positive for the parking lights. and the other wire i think is for your main power source(battery or whatever you use).
what I did to my previous 7th gen to my fog lights are i cut the both harness ...the white wire you can tap to the fuse box (you need tap fuse) and the red wire you need tap to the + postive parking lights to light on your switch or you can tap to your moon roof switch just find the wire where is the + postive ....
Discussion Starter #7
thanks guys... i'll check it out again and see. any one of you live in nj? duck17 i got your pm and ill call you when i have the wires all out thanks!
If I buy mine aftermaket for my 2004 sedan,do u guys know if it will come with the templates to help me cut the bumper? And would it be the same procedure?
Green clip- plug directly into the switch.
Gray clip- Cut off the clip and wire to parking lights.
Brown clip - Cut off the clip and wire to power.
All of those can be wired under the dash behind the fuse box.
+1
if you cant wire it based on that information maybe you should take it to a shop
Discussion Starter #19
what color wire is the parking lights?
1 - 20 of 21 Posts
