Recently, mid-november 2010, my battery light came on so i drove to advance auto and they said the alternator was dead. i replaced the battery previously in May of 2010 and the car had 144K at that point so i bought one from them and replaced it myself. about a week after installing it my car hardly cranked up one morning so i had the battery tested and although it said it was low and needed to be re-charged it was good (12.63 volts) per advance auto again. they tested the new alternator too at the same time and it checked out well producing 14.35 no load and 14.11 volts loaded. they also ran a test for the drain on the battery and with everything off it showed a 7 amp draw. i had them re-test it 3 days later and it had a 2.36 amp draw. i read on line to check and by putting the pos probe from a multimeter to the positive terminal on the battery and negative to negative to check for AC current which i did and with the car running it read 25.4 volts AC. the site i was on said if it showed any AC current than a bad diode was to blame in the alternator so i took it back and replaced it with a new one that they bench tested before i installed to ensure the diodes were ok in this one. after installing the 2nd alternator i brought it back to have it tested and it showed battery still good but in need of recharge, alternator 14.37 volts, 8.1 amps no load and 14.14 volts, 6.9 amps; .45 amp draw with everything off. thinking i had solved the problem i drove my car on a 400 mile trip to my folks house where it then stayed parked for 36 hrs before it was restarted and it seemed a little weak starting but did ok. the rest of the trip was fine drove 400 miles back home and everything seemed ok other than the occasional weak start on a cold morning until it snowed here and it sat parked for 3 days in the garage with the key in the ignition when i went to restart it again it was hardly able to start. i have gotten a new battery today because the other one from May was finally deemed no good but the computer at Walmart said there had been a significant parasitic drain on the battery.
i came home to check everything out with my multimeter again after getting the new battery in and came up with a drain that ranged from .035 amps with the key out of the ignition to .055 with the key in the ignition (multimeter in 10 amp setting). i don't know why it would make a difference with the key in or out of the ignition as nothing was turned on nor was the key in the ACC position it was just slid into the ignition and repeatedly came up with the same readings.
i then started pulling fuses if i removed #15 from the fuse box under the hood it zeroed out the meter - no draw at all and that fuse is labeled "back up, ACC" otherwise i only saw a .017 difference if the #7 "back up" was removed from inside fuse box or .04 difference if the drivers side pwr window fuse was pulled. all other fuses did nothing with the exception of the radio which was only .01 difference. i would think these draws are normal but am not sure as these fuses control devices with memories?
the thing that seems most unusual is the difference of the draw with the key in or out of the ignition.
i should also mention that i typically drive approx 60 miles a day with probably 8 - 10 starts within that distance (i am a local traveling salesman), i do have days where i drive 150 miles and still start the car approx 8 times.
any thoughts or help would be very appreciated; i feel like i am getting close but would like to be done with this and have solved the problem.
