wow! Exactly what I have been trying to relate.thank you.but mine is an l4.is it normal for an l4 too? The car is like 8months old, bought it with about 90000miles on it.I started noticing it like 3months after I got it.I had given it to an auto mech to drive, and he said there was nothing abnormal with it.iv been worried,hoping that my transmission is not about to give way.I don't really have experienced with cars,as this would be my first.i love the car
I get the sense that you are just looking for reassurance here. Like everyone is telling you, don't worry about it. Nothing you are describing sounds abnormal. As for the i4 - I'm not sure if it has the same operational features as the V6 (beyond the obvious). If you're really curious, you could ask Honda if the i4 has "torque reduction shifting", or maybe someone on here can tell you. I don't think it changes what everyone else is telling you though.
Abnormal would be:
- Violent shifting,
- Banging, knocking, grinding or scraping sounds coming from the trans,
- The "D" (meaning drive, when you put it in gear) light on your instrument cluster flashing,
- RPMs suddenly kicking up when shifting (flaring),
- Not engaging into gear when you put it in drive, or disengaging from gear during driving,
- Shuddering when the converter clutch engages at highway speeds, and
- Dark trans fluid that smells like burnt toast and has black bits in it.
And, a car can change how it feels during driving over time as it ages. If you're observant and you come to know your car really well, you'll notice rattles here and there start coming in, things aren't as smooth running as before...like people I guess! :lmao:
I would do as others are suggesting and do a 3X drain and fill, just for some self assurance. Make sure you use Honda DW-1 fluid. Have a look at the old fluid that comes out and check to see what has stuck to the drain plug (the bolt that you remove to drain the fluid). If you're not mechanically inclined or uncomfortable doing that, then you might want to have someone else do it.
Good luck!
