I replaced most of the front end suspension components myself on my 02 Accord 2 years ago including both control arms, tie rods, ball joints, and sway bar bushings. At the time, the vehicle had a lot of noises - bushings shot, control arms rusting through, etc...since replacing the parts, the ride is appreciably better. The washboard feeling is now gone, but I do have a persistent popping noise coming from the front end, on both sides of the car. The noise only occurs when: accelerating from a stop, braking, and especially when both braking and cornering (driving through a parking lot for instance).
I think its either the struts (or their mounts) or the radius rod bushings. I've never seen any leaking from the struts however and the car doesn't have much bounce when going over bumps. I also tried rocking the car with the hood open so that I could see if the strut mounts were shot - nothing seemed out of the ordinary. They are original OEM. Is there a way to test the radius rod bushings? I was also told that it might be "spring bind" - how would I check for that?
TIA for any help!
TIA for any help!
