How is that working and what does it say, exactly, see below:
I saw a review video which said that you can lock it at your preferred setting by holding the paddle for a bit, and it will then maintain that regenerative setting between starts.I like it at level 6, and I set it that way. I don't even know what levels 1-5 feel like. It may regenerate when you use the brake, I don't know. What I like is there is no need to touch the brake. You are converting the forward motion of the car back to electrical energy via the generator motor, and that slows the car, not the brakes. The brakes should last forever like that.
No, that is not the way I understand it. The regeneration is independent of the braking system. While you may be right that there is some regeneration when you use the brakes, you can use the regeneration mode without the brakes. Why do you get so touchy when someone disagrees with you.
This doesn't make senseYou are correct Larry. The brake pedal in our hybrid accords are connected to a pushrod that inserts into the hydraulic master cylinder that is on the driver side of the firewall under the hood. There is a reservoir atop the master cylinder that holds the brake fluid. This system is known as the ‘service brakes’.
The regenerative braking system is actually fed and felt by the same electric drive motors that propel the car. When energized with electricity, these motors make the car go (like a drill motor, fan motor, etc). When you lift off the accelerator the flow of electricity ‘going to’ the drive motors cease, and while you coast the motors put out electricity as long as the front wheels are turning (like a belt driven air cooled Volkswagen generator) that is routed to the hybrid battery pack and stored until need to propel the car, or operate electrical accessories. It takes force to turn a generator motor (think power plant inside a dam on a river).
When power output from the hybrid motors, now turned into power generators, is increased (the six increasing load levels set by the left paddle, right paddle reduces the load) the car stops more aggressively until it gets down to around 7-8mph, when you have to apply the hydraulic service brakes if you want to come to a complete stop.
At regenerative braking level 4, the software activates the brake lights so that motorists behind you can see that you are slowing.
Just by lifting off of the accelerator pedal the default regenerative level is 2 unless you are in Sport mode and the little M is lit in which you can set the level of regen braking and have it stay put. In other drive modes, you can pull and hold the left paddle for 2 seconds to activate M(anual) regenerative mode, or pull and hold the right paddle for 2 secs to deactivate.
There is no ‘braking by wire’ on our cars when pushing the service brake pedal. It is hydraulic with regen blended in.
EV light means it is electric propulsion only AND THE ENGINE IS NOT RUNNINGOK, another dummy question:
When the green EV lights up, what does it really mean, that there's energy going to the battery (recharge), or is it also indicating the car's getting energy to move from the electric motor?
And in general, when accelerating from zero, does the Accord get its energy from BOTH the 4cyl engine and the electric motor? After all, a 2L engine is quite weak to accelerate alone a big car like the Accord, right?
Who in the what now?I think you are wrong about that. The brakes have nothing to do with slowing the car. It's the resistance of the generator motor while it generates electricity that does the slowing of the car, not the brakes.
Right... The idea is that the speed of the gas engine (or even whether it's running at all) doesn't really matter.What's interesting is there's no RPM gauge on the instrument cluster...
Like Marty said: the latter. The gas motor is NOT running in "EV" mode.When the green EV lights up, what does it really mean, that there's energy going to the battery (recharge), or is it also indicating the car's getting energy to move from the electric motor?
I'm curious about this, too... I've read all about it, and I'm not stupid, and I'm a bit of a motorhead, and I stilllll don't understand.And in general, when accelerating from zero, does the Accord get its energy from BOTH the 4cyl engine and the electric motor? After all, a 2L engine is quite weak to accelerate alone a big car like the Accord, right?
Larry, I value your input here, but when you make statements like the one above, which seem patently absurd (but admittedly kind of make sense in context), then you shouldn't be surprised when people argue with you...Why do you get so touchy when someone disagrees with you.
So I was just out driving my EXL, and yes indeed it is as I said...in normal driving mode (ie not using the paddles to set a specific regen level 1-6) when you start braking, the "power generation" increases which means regen braking is happening. If you are going fast and brake with some force, it will peg the regen braking. Only when you start to get slow will you see that the power gen starts backing off and then when you are really slow it goes to zero, and so at that time the last little bit of bringing the car to a complete stop is handled by the mechanical brakes.This doesn't make sense
When you depress the brake pedal from speed, why then does the % of regen braking increase? (lower left quadrant of the power dial) If you push harder on the brake pedal, the power recovery increases.
Where do you see "the regen %" on the display? I don't see it....you will see the regen % go lower...
I will not invent my own definitions of how the braking system works in this 4th generation Honda hybrid. Here is a quote from Honda's technical bulletin. I leave interpretations according to someone's personal beliefs....So whoever above claimed that this car just have mechanical brakes and the brake pedal isn't "brake by wire" must be wrong. ..
Right, it isnt a basic mechanical linkage just to the master brake fluid cylinderI will not invent my own definitions of how the braking system works in this 4th generation Honda hybrid. Here is a quote from Honda's technical bulletin. I leave interpretations according to someone's personal beliefs.
"During braking or when coasting, the propulsion motor converts the kinetic energy of the decelerating vehicle into electrical energy to recharge the battery. The brake system seamlessly coordinates mechanical and regenerative braking with an electric-servo braking system for natural, linear, and responsive brake performance and pedal feel".
It is the lower left quadrant on the power meter (from like 6:00 to 10:00 position). At the 10:00 position it is basically at neutral, neither charging nor discharging. As you accelerate the power output rises and the needle moves clockwise. As you are Regen braking the needle moves counterclockwise down toward 6:00...the further down it is the more charging power is being created from the RegenWhere do you see "the regen %" on the display? I don't see it.
Agreed, but some people are going to like the "one pedal" method, and as Honda points out, you can basically use the paddles to increase regen to slow the car on long downslopes (like downshifting in a normal car).So, no need to eff around with the paddles because you still get regen braking through normal driving, was my original point.
So you insult me without telling me why you disagree with me. I'm just absurd?Larry, I value your input here, but when you make statements like the one above, which seem patently absurd (but admittedly kind of make sense in context), then you shouldn't be surprised when people argue with you...
Can you not see the absurdity in this statement? LOL...The brakes have nothing to do with slowing the car.
So you quote me completely out of context, and then want to get smug with me?Can you not see the absurdity in this statement? LOL...
Listen my friend
What you're saying is wrong. I mean yes, "you can use the regen" without touching the brake pedal. But that DOESN'T MEAN that when you press the brake pedal, you are somehow not using the regen in the same way. I don't know how many times to keep saying it, but the car uses plenty of regen if you drive it "normally" because when you press the brake pedal, it will use regen as much as it possibly can to slow the car BEFORE it uses any mechanical brakes. It is as if by pressing the brake pedal, the car is moving to your "level 6" in the same way.
