So I noticed that I had a leak somewhere on my power steering pump. I tried cleaning it up as much as I could but power steering fluid is hard to clean. Anyways, I had my wife start the car and turn the wheel for me. It started immediately leaking from the outlet hose (red arrow). I turn the car off, clean everything up. Undo outlet hose make sure everything looks ok. I tightened it back on. Start it up and try again. This time no leaks from the outlet hose. I turn the car off and slowly from the power steering pump cover(green arrow), a leak formed.
I'm wondering if its worth it to try and redo the seals and o rings in the pump to see if it works. I read some things online where it seemed to work for some people. At the same time, many are just saying to get a new one. Anyone have some experience on the job of redoing the seals and o-rings? Is it difficult or worth it?
Also, I got some powersteering fluid on my belts? Someone said to use brake system cleaner. Is that ok for the belts?
