1 - 3 of 3 Posts
My question is for the owners of the 1.5T PRL intake tube with Ktuner. Has anyone data logged the MAF sensor before & after to see if there was a increase in airflow.
Question: If the tube does its job, then wouldn't it be the reverse as a given amount of output power would be net of less pumping loss, therefore less fuel consumption, therefore less airflow?
So this also applies when a less restrictive filter is added, but at WOT there should be an increase in airflow if the tube or filter has a restriction? Then we would see an increase in voltage from the MAF compared to stock?
1 - 3 of 3 Posts
