1 - 8 of 8 Posts
What speaker adapters/harnesses fit the two front door speakers and the two rear deck ones. I looked on eBay and most kits stop at 2012 accords.
They haven't changed. Honda has been using the same connector for years. Here is the link.
http://bit.ly/SKkNUs
Thanks!
What about the adaptor brackets?
Noob here, quick question. Adapters are needed for any aftermarket speakers? As long as they're 6.5" or 6.75"? And adapters are for plug and play?
Do you have a reference for taking apart the rear deck, or is it self explanatory?
There are instructions on various threads in this forum. It's a pain but can be done. I personally didn't use adapter brackets for the rear speakers. I drilled holes in the factory brackets. They lined up already.
You can use the factory ones if you don't mind drilling into the plastic. Not sure about 6.75. 6,5's fit fine.
1 - 8 of 8 Posts
