1 - 11 of 11 Posts
2009 accord ex 4 cylinder
I will buy it now for the firts time! Hopefully autozone or pepboys have them. Can I mix tit with regular windshield fluid
BACK TO THE FUTURE!!!
you can dilute it as much as you want. it won't harm anything. you may not get a good performance from the beading action, cause of the solution being diluted though.
just FYI.
i have used it for years, and swear by it.
Premium Member
I treat the windshield with the concentrated Rain-X windshield treatment and have been since the mid 80's, and use the the Rain-X wiper fluid as well, there is a summer formula and winter formula, obviously with more alcohol content in the winter fluid.
Have you heard the windshield fogging myth? I don't use the actual treatment stuff for that reason, but I see no issues with the washer fluid.
Can anyone shed some light on this?
Premium Member
There is a little bit of haze from Rain-X concentrate if you don't buff it off really well, kind of like wax streak on painted surface if you don't buff it off well, but no there is no "windshield fogging" that I have ever experienced.
As I said I've been using Rain-X since mid 80's when it was called Repcon, it's one of those magical chemicals that really works.
Nothing beats a personal testimony. I have some out in the garage, it may be worth giving it another shot, especially since I really dislike using my wipers anyway!
Freelance Gynecologist
Also use the Rain-X concentrate. As Aviography said, you really need to buff it off properly. Follow the directions properly, and it works well.
Personally I spray down the windshield with a glass cleaner and then I use a clay bar to get the fine stuff using the glass cleaner as a lubricant. After I get the windshield clean enough, I apply the rain-x and I'm pretty happy with the result.
I've heard many great things about this product. If you guys wax your car, some good wax will also have the same effect. Not sure if it'll be as good as rain-x, but it works. When I wax my car with Zaino Z-2, I apply it to all of my windows also and it does wonders in the rain.
1 - 11 of 11 Posts
