For those of us who have actually sent oil in for analysis, changing the filter every other oil change did not have any effect on the lab results, so there's that.
This is my thought process. Sure, you won't see any ill effects right now. It takes time to see damage. Look at the human body for example. You can eat like crap or be exposed to toxic materials when younger and seem fine. When you get older, the ill effects of what you did when you were younger start showing up in full force. Yes, some people get lucky because of really good genetics, but that's not the norm.
It's the same situation with your car. Yes, some neglected (not necessarily saying this is you because you change filters every other interval) cars will make it, but that isn't the norm. When you don't change the oil filter, that oil filter still has old, contaminated oil in it. This old oil mixes with fresh oil and contaminates the fresh oil faster than if it were just fresh oil. Luckily, Honda oil filters are small and because of this, there isn't a whole lot of old oil to mix with the fresh stuff. On the other hand, oil filters efficiency goes up with usage (to an extent). An oil analysis is a good start, but there's a better test here. Cut open an oil filter and see how much crud the filter has in it. Make sure the filter hasn't broken down enough to warrant a fresh filter. The reason I'm torn on this topic and decide just to change it every oil change isn't because I don't believe Honda, but it's solely because of oil filter quality these days. Most oil filters aren't built well enough to stand up to something like this. Even some of the ones rated for extended intervals don't look well built when they are cut open.
