1 - 8 of 8 Posts
Doc Mojo
Initial post can be found in my build thread here:
http://www.driveaccord.net/forums/showpost.php?p=792963&postcount=290
don't forget to check out my build thread
Things you'll need:
a) needle nose pliers
b) soldering iron, solder, heat shrink wraps
c) extra wires if needed
d) wet napkins
e) fishing lines/dental floss (not necessary for me)
f) heat gun
Step 1:
remove trunk lining
Step 2:
use heat gun with LOW HEAT to gently go over the stock emblem
Step 3: remove emblem by pushing upwards using a needle nose plier. The emblem may still be held onto the trunk by 3M tape. Simply apply heat gun and pry off SLOWLY
Step 4: clean surrounding area with wet napkins.
Step 5: thread wires through the 2 pin holes.
Step 6: remove tape protection and apply gentle heat and press onto trunk
Step 7: splice your parking light connectors. Note: the parking lights already have the cathode/anode in red/black coloured wires.
Step 8: solder/protect the emblem wires onto the spliced wires.
Step 9: enjoy!
Reverse
Looks very nice. Thanks for the DIY. What kind of shoes?
Hey Guys,
In case you haven't seen one of the latest on other threads, here it is.....
Extreme blue on a 2010 Accord Coupe.
1 - 8 of 8 Posts
