my headlights actually turn on but just not the rear including the license plate lightsThere should be a fuse diagram somewhere in your manual. I'm sure someone probably knows which it is, but I blew a couple of headlight fuses when I was messing with my HID's and I found which it was in my booklet. If the taillights are with the headlights, I think the fuse panel is inside the front passenger seating area, under the dash or the side, I forget.
Nope but i fixed it somehow haJust start checking every fuse. Were you doing some kind of electrical work/mod on the car? You need to figure out and correct whatever issue caused the fuse to blow.
I actually checked all the fuses but i went back to #27 driver's side and #2 passenger's side fuse boxes. They were good but i replaced them anyways just in case and they started working. Weird eh? Whatever the case I'm glad they're fixedHad the same problem a week ago, I believe it's Fuse# 27 (Driver's Side Fuse Box): Left Side Small Lights (Exterior).
