So I got burned...the guy took 7 weeks to do my tranny and now it runs great but I have no airbags or horn and he is no where to be found...now what?
Thats why im never going back to AUTO !!!!!!!!!So I got burned...the guy took 7 weeks to do my tranny and now it runs great but I have no airbags or horn and he is no where to be found...now what?
A shop did the work on mine. That explains it now. I find it odd that the clock-spring would go out right after the transmission job. I opened up the bad one and the ribbon was ripped.Did you pull the joint going to the steering rack?
If so, the steering wheel needs to be locked while the rack is removed.
Otherwise, the wheel will turn beyond one side or another, destroying the clockspring (or airbag sliding contact, in Honda speak).
The air bag light is on and the horn works when I hit the key fob twice...Now this is a strange coincidence. I did my Transmission earlier this year (took a day...hours). When I got it back I noticed the airbag light but I thought it was the seatbelt buckle. Then a few days later I went to honk the horn and nothing.
At first I though maybe the shop removed a harness and forgot to put it back. Then the cruise wouldn't work. All the above issues can be caused by the horn relay being bad. I have a shop manual so I did all the test and it turned out the clock-spring (cable-reel).
Does the horn still honk when you press the lock button twice? There is a single pin connector on the steering wheel harness that will honk the horn when grounded. If you turn the steering wheel 180 degrees from center and remove the little cover from the under-side you should see the yellow airbag harness and a black connector. Ground the wire in the black harness and the horn should honk. If it does then you most likely have a shot clock spring
You will need to remove the airbag and steering wheel to get to it.
Check all horn related fuses first though.
How many miles did your trans last?Yes. I had to replace the clock-spring.
Did you install this yourself? If so, any where I can find a how too?Yes. I had to replace the clock-spring.
