1 - 6 of 6 Posts
Is the remote roll down windows feature only for EX or upper model?
I tried to do it on my sport but it wont work:boohoo::boohoo:
I am not sure if I did it right or it just doesnt have this feature in the lower trim model.
Only works with the smart key. Sport doesn't have it :(
Elvira
doesn't the key trick by twisting the key and holding after the second "unlock" move rapidly open all the windows even though no smartkey?
I know it's not remote but it is handy if it works on the Sport.
edit: manual states even that might not be on all models.
Miker
joethefro
Mine is 8th gen 2008 coupe exl v6...
I'm pretty sure it should work with your EX model. I have the EXL V6 and I just got mine fixed from a Honda dealership. The moonroof will also open. If yours is not working I highly recommend having it "reset." I didn't have to pay $ because my car was being repaired from a fender-bender. So, when they did the required testings of the electronics, it must've fixed it :)
Generation 9
Yep I had a EXL V6 2011 Sedan and had this feature as well.....And it wasn't the smartkey entry system on that model...Took a while to get used to because you have to click the unlock twice, the second time holding the button down until all the windows lower to where you want them to..You can't let go or the windows won't go down......This was a mistake I made for awhile thinking it did not work..I let go too soon...
1 - 6 of 6 Posts
