I did change the oil today. But the loop oil wrench was too big, and so I couldn't get the filter off. I'll be getting a new wrench tomorrow.But, I have to ask why are you removing the filter right now as opposed to at the oil change?
For 4 cylinder engine, you will make a lot of oily mess behind the engine block. also, oil filter needs only hand tight, no need for wrench unless it was tightened by dealer tech or fast lube type technicians with 100 ft-lbsI did change the oil today. But the loop oil wrench was too big, and so I couldn't get the filter off. I'll be getting a new wrench tomorrow.
The last oil change was at a lube place. It's too tight for me to loosen by hand.For 4 cylinder engine, you will make a lot of oily mess behind the engine block. also, oil filter needs only hand tight, no need for wrench unless it was tightened by dealer tech or fast lube type technicians with 100 ft-lbs
I had the same situation on another Accord and ended up stabbing a screwdriver through and taking it off. Worked in a pinch and I didn't have to wait for laterThe last oil change was at a lube place. It's too tight for me to loosen by hand.
I just bought this one from Home Depot tonight, so I don't have to wait for a shipment from Amazon. It has good reviews and is durable, with a lifetime warranty with no receipt required. I tested it on the new filter and it fits snug. I'll give it a go in the morning.Yes, the vast majority of the oil is in the pan. A small amount will be in the filter and retained by the anti-drainback valve (~0.5 qt). Have some new oil on hand to adjust the level after replacing the filter.
I've been using a rubber strap wrench to remove my Accord's filter. But I finally upgraded to a jaw type. Next change will be the first time using it. I've always remembered those working so well from my short stint as a lube tech. Those metal band type are the absolute worst, I've never had any success with them.
These aren't a bad option.I just bought this one from Home Depot tonight, so I don't have to wait for a shipment from Amazon. It has good reviews and is durable, with a lifetime warranty with no receipt required. I tested it on the new filter and it fits snug. I'll give it a go in the morning.
