1 - 1 of 1 Posts
How do you remove the parking brake cable from the caliper on a 98 accord ex v6. I've taken the cable end off the lever on the caliper, but I can't remove it from the bracket. Is it pressed in the opening of the bracket on the caliper or is there a tool or what?
I think I need to replace the caliper because the rim gets real hot and the wheel is locked when I jack up the car. I've manually retracted the piston with the piston tool and socket, and when I reapply the brakes the wheel locks up again.
My local auto parts shop gave me a replacement caliper, but it's not exactly the same. I was going to swap the bracket from the old caliper to the new, but it's configured differently and not exactly the same as the original.
Any help is appreciated
Thanks
jamey
1 - 1 of 1 Posts
