1 - 18 of 18 Posts
Hi everyone. I’m currently working to get the passenger side axle replaced on my 2006 but the axle nut is REALLY stuck on there. I’ve tried heat, penetrant, my electric impact, and a long breaker bar. I even jumped up and down on the breaker bar but nothing. I now am trying to dremel the nut off with little success so far. Anyone have any ideas to get this axle nut off? Should I just keep dremeling away until its cut off completely?
Turbo lag
How powerful is the impact you're using?
Cruising in Montana
How is a Dremel going to do what an electric impact, heat and a breaker bar can't do?
Cutting that nut likely requires a hand-held grinder with a cut-off wheel. You can rent them.
The impact is a ridgid 1/2 inch impact, not sure on the exact torque of it.
I got a small notch of the nut cut off with the dremel, but it still won’t budge. I do have an angle grinder, so can give that a try.
Angle grinder and then the impact gun FINALLY got it off, thanks guys! Now to replace the axle and get 1 new stud since I nicked it.
Well, anyone have tips on getting the axle out of the intermediate shaft (5MT Tranny). Im beating on it with a hammer and pry bar, but no luck. Is there a tool I can rent to help out?
07V6 EX-L Chicago
The axle nut is torqued at 185 ft-lb. With rust, you may need at least 300 ft-lb or 400 ft-lb to move it. Your electric impact, often 200 ft-lb, good enough for most lug nuts, but under powered for axle nuts. With a good gun, dremel and grinder are not needed.
Reactions: WDHewson
Yeah I’m going to have to invest in air tools whenever I have the money and space. For now I’m glad I at least got that part off. Now I’m having trouble removing it from the intermediate shaft…I’ve been trying a pry bar and hammering like it says in the FSM for a manual transmission with no luck.
Well for anyone who may come across this thread in the future, I finally got the inner joint out using this method in this video:
07V6 EX-L Chicago
...I’ve been trying a pry bar and hammering like it says in the FSM for a manual transmission with no luck.
The axle is secured in the mid shaft only by a snap spring. Do you have a metal rod? or long screw driver. Line up the rod almost parallel to the axle, hit the rod with a hammer, it should come out without much difficulty. The problem with pry bar is that it has a little cure at the end, and you need force parallel to the axle.
Reactions: Hudouc
Discussion Starter · #10 ·
I will have to keep that in mind for next time, thank you. I was able to get it out by using vice grips and reinserting the shaft, then pulling.
I bought a Bauer 1/2" Electric Impact from HFT a few years ago; it's rated about 1000 foot pounds of torque; which is probably an exaggeration. However, it has never met a bolt or nut that didn't quickly yield. About $100
Air tools only work well with a very large air tank and hoses with larger than normal I.D.
My 1/2" impact just rattled forever on the 19 mm crankshaft pulley nut on my 1999 CR-V.
I bought a breaker bar of about 3 feet, and properly supported, my average strength made short work of it.
Discussion Starter · #14 ·
Is this the one you purchased?
2015 Accord EX sedan 6MT Alabaster Silver
I had an axle nut I couldn't get off with my Ryobi impact driver 1/2". I drove to local mechanic and asked him to use his air tool to loosen, and then tighten for me again. Drove home and finished my job.
A good long breaker bar usually has more torque than a impact gun depending on how you apply force too it. Since your leg muscles are typically stronger than your arm muscles...
1 - 18 of 18 Posts
