I'm having trouble removing the timing chain cover on a 2015 4 cylinder (replacing head gasket), and I don't want to push my luck in applying too much force prying to break the hondabond seal. I checked over and over and have removed all the bolts (I think I counted 21) holding the cover on from the front perimeter and bottom, as well as removed the VTC control solenoid, engine mount, rocker arm valve, and crankshaft pulley. Nothing else but the sealant seems to be holding it on, but I don't know how much force I need to break the seal. Is it a pretty significant force? Is there a best place to pry from? I've tried tapping on the ear at the top of the cover and applied light-moderate force prying between the head and cover by the gears, but I don't want to damage anything.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
