1 - 20 of 23 Posts
04 Accord V6 6spd
Got my retro in yesterday from Greg (LFsoccer2k6); looks great..
and also finished making my fog strip; inspired by Chris (KingMooCow)
more pics seen here on this album:
http://s242.photobucket.com/albums/ff203/ntextreme3/retro/
btw; should I go with red turn signals for a while? i feel like the switchbacks and the strip clash because theyre slightly different whites
oh and-- im currently sitting outside right now on my laptop gaurding my car because some black guy just got punched in the face and car jacked right out here.. i was like wtf.. some kids told him to check his gas tank cuz it was open and he got out too looked and they dropped him and took the car he started screamin to call the cops.im glad im leaving for work in a second lol
I'm liking those led strips. I've seen a lot of different cars try to copy them and the mercedes design and it never looks good. Those looks pretty good. Do they actually throw off any light on the ground or mainly just for looks?
04 Accord V6 6spd
I did it for show but the output is really spectacular. Not so much the ground output (I wouldn't drive far at night with them, though you could definitely see enough to manuver around and I'm sure if they were aimed toward the ground a little more it be more possible) but as you get farther away it looks really really bright. I tested using a potentiometer as a dimmer, which works nicely, though I haven't hooked it up yet. I don't want to blind anyone at night. They're small but really powerful. Ill see if I can get a pic of that tonight if it stops raining
Driving is my hobby
The retro looks hot. But on the other hand, I dunno about NJ cops but u might get some heat with those red angel eye rings. If you go red on the turn signals, you might as well be asking for it...
04 Accord V6 6spd
Discussion Starter #5
Yeah.. I was thinking the same thing. I'm not worried about being around town here because most of the officers leave me alone cuz I'm always working. I work where they all eat so I haven't been ticketed since I got this job. My worry was just trips to places other than here lol. Maybe ill just keep the red led turn signal bulbs with me and switch between them and the others depending on where I'm going. Only takes like 2 minutes to swap them. Haven't decided
04 Accord V6 6spd
Discussion Starter #6
took a while, but here are some pics, all taken same exact way. (the dark one is lights off; just to compare-- the second is fog strips/parking lights, the other is obviously headlights).. the last is fogs and parking again.. showing off the door handle/mirror led lol.
Coldspeed
Looks good man, I like it. I have a somewhat similar idea, although since I want to retain the use of my fog lights, I was thinking something along the lines of this:
Note: Old car pic, dirty and lame! Red line = LED's. Would have them hooked up to their own switch, so I can turn them on/off whenever. Also I would try to 'hide' them in the crack, or have them drilled and embedded into the fog light "grill".
04 Accord V6 6spd
Discussion Starter #8
Mine comes in two parts. I'm sure your fogs would be the same. If you went with drilling in that particular area, you'd have to find another way to mount the covers. Shouldn't be hard. I'm putting mine on a switch too. Eventually. I also hope to get an oem fog switch and hook that up to my strips. That would probably look cool. Only way to know is to do it hah. I was worried about when I did this because it looked nice on 'kingmoocows' car but my covers are a little different so I wasn't sure. And mine are angled. A lot. So I had to drill at an angle that I thought would point straight in front of the car. I was off a bit, but the effect is really nice. I actually wound up liking it being off a bit.
What projectors and shrouds did you use? I'm feeling the angel eyes alot.. maybe I'll do blue/white/or run angel eye less. hehe.
04 Accord V6 6spd
Discussion Starter #10
Mh1 projector with e46 shroud. Got them from greg. I like the red a lot more than I thought I would, and I never want to drive without projectors again lol (if I haven't already said that). My favorite pic of the red so far is on my flickr or facebook somewhere. Ill see if I can get it when I get home tonight
loves his accord
love the LEDs
about to start mine actually
did you run the leds in series or parallel...im guessing parallel right?
those look like 5mm right?
04 Accord V6 6spd
Discussion Starter #12
for the fog strep; yeah. parallel. Cut part of one leg off each led and soldered a resistor to the cut leg (so it wasnt so huge), then twisted all the + and all the - legs together; then soldered each intersection. Soldered two wires at the end, and filled it with silicon.
04 Accord V6 6spd
Discussion Starter #14
cool
just noticed but what/how do you have leds under the mirror and door handle
very cool
Thanks; I like how it came out. I wasn't sure at first. It was something I wanted to try for a while than one day I just went for it. Driver's side door was the biggest bitch in the world haha. Since I wanted to keep everything factory looking, I chose to run my wires along side of all the factory door wires which meant running them through that rubber protective tube between the door. Which wouldve been fine if it wasn't blocked by this annoying harness/connector thing. The LEDs are just some of many 5mm leds that I have laying around. If you look under the mirror theres a hole that fits the 5mm LED so perfectly you think that they made it with this in mind. actually now thinking about it i probably shouldve taken a better pic of the mirror. I guess i got so caught up in getting pics of the door handle cuz that was my main goal. The mirror was like 'eh since im here already why not'. I ran those wires up the spindle of the mirror with the other wires for the motor.
Heres my first post about it, scroll down and youll see a buncha pics describing the whole process (at this time i did one side to see how it looked and hadnt done the mirror yet):
http://www.driveaccord.net/forums/showthread.php?t=51354
Than heres another post after I did the mirror showing the driver side door complications:
http://www.driveaccord.net/forums/showthread.php?t=51765
how did you get your turnlights that bright? or is the angle of the picture? are those red halos or leds? im talking with greg now about getting some retros and have been going back on forth on the halos or not but those look sick
What did you hook up the LED fog lights too? Separate switch or hooked into the parking lights or something?
7th Gear
Is that different from some "guy"? :thumbsdow
Glad you think that is funny. :thumbsdow
04 Accord V6 6spd
Discussion Starter #18
Thanks! They're LEDs behind the e46 shroud, he'll remember, or you could just send a link here to him. They're up on their website as well I believe.
04 Accord V6 6spd
Discussion Starter #19
They are in the parking lights, but I planned on making a switch. Just got lazy.. when It's nicer out I'll do it
04 Accord V6 6spd
Discussion Starter #20
It's called telling a story and being descriptive. It's easier to see what's going on that way when reading it. Where did I ever say it was funny? If it was a joke I wouldn't have been outside guarding my car. He went into a rant and started punching parked cars.
1 - 20 of 23 Posts
