1 - 6 of 6 Posts
Changed a tire today and found a bunch of grease on the inside of the tire. seems like a bushing has ripped. any thoughts?
524217
I would guess that your CV boot cover is ripped. Is there a spray of grease that goes our radially from the CV boot? See if there is a tear in the boot. Hopefully the CV joint is ok and all you need to do is replace and repack the boot. If you feel/hear a clicking noise when you turn the car, the cv joint is bad and you will need to also replace the axle.
I dont see a tear anywhere, I dont hear a tick when the engine starts. The inside of the tire was all black with the grease. How long can I drive like this for?
Turbocharged
You probably need to pry at the boot with your hand to find the rip. Get it taken cared of ASAP or you'll be looking at buying a new CV axle. All that grease is there for a reason.
Reactions: 2Accordz
I agree with Hudouc, I'd get the boot replaced asap otherwise it will cost a lot more. All it takes is a tiny hole and the centripetal force of the tire rotation will fling all the grease out. I understand the 1 piece boots are better than the split boots, but they will cost more to install. I'd check the other side too for leaks.
Pry open the boot's many folds with your hands, there is a rip in there. That's the only source that would contain black grease in that area, nothing else.
1 - 6 of 6 Posts
