1 - 5 of 5 Posts
So I installed my RV6 J-pipe about a month ago and I've had a CEL ( Check engine light) on since then. Haven't had time to check but we plugged her up to check what the code was, of course it was the O2 sensor ( on the j pipe, secondary). Come to find out that one of the wires on the O2 sensor was backing out of the plug/socket on the engine harness side. So if you are having an issue after you install you J-pipe make sure to plug your car up and definitely check the O2 sensor!
Because it's not a "simple upgrade"!
What are you trying to inquire about?
What's the difficulty in this header? I ordered it online for them 5 days ago and haven't heard any response back......maybe I'll just do a second ct delete. Cheaper anyway
Discussion Starter #5
Have some patience, call them see what's up.
1 - 5 of 5 Posts
